issue : while changing from state “CBT_CS_CAP to CBT_VREF_SET” coverage bin has not hit, but while observing the wave form this transition is happened.
please find the following is the code :
In reply to k@nth_nethula:
I guess this is code snippet from a case statement of your FSM. Could you please post the definition of your transition coverage.
This might be caused by your iff.
BTW the statement iff (prev_cbt_state == CBT_CS_REQ) is not necessary because of your bin definition.
thanks for the reply
if i remove that iff (prev_cbt_state == CBT_CS_REQ) still the bin isn’t hit
I guess your FSM is in your DUT. In which language is it implemented?
How do you connect your coverage collector to the DUT? Are you using the bind statementand were you checking the wave forms of your phy_intf?
