Unable to retrieve config_obj
I have an error in retrieving the configuration object after compilation. May I know why am I not able to get the object.
Here is the link to APB_BRIDGE
In reply to sai_pra99:
You have several typos
In your apb_test, you wrote
uvm_config_db#(apb_config)::set(this,"*apb_agent*","m_cfg",m_cfg);
but it should have been “apb_agnt”.
In your clocking block, you wrote
output paddr,psel,penable,pwdata, paddr;
but you have paddr twice.
In your apb_agent, you wrote
if(!uvm_config_db#(apb_config)::get(this,"*","m_cfg",m_cfg))
The “" should have been the null string “”. Although either works in this case because of the wildcards used in the set. You are actually doing a get at a level below the context of the get(). The uvm_config_db treats the context as {this.get_fullname, “.”, "”} which is “uvm_test_top.env.apb_agnt.*.m_cfg”.
