how UCIS(unified coverage inter-operability standard accellera 2012) can be implemented in a UVM environment?
what are the requirements for such an implementation?
Are the supporting libraries/packages open source?
In reply to SHIKHA SRIVASTAVA:
The UCIS API is a C language API that helps extract or write information into coverage databases that support the UCIS. Since it is C-API it can either be used in post-sim or in simulation in any env. (e.g. via SystemVerilog DPI/PLI). The API is open source as defined by the standard, the implementation is tool specific. To use the API your simulator needs to support the UCIS API for coverage databases.
