I’m trying to implement a uvm scoreboard. While creating the uvm_analysis_imp and connect it with the monitor. I’m getting following error.
ERROR: formal and actual do not have assignment compatible data types on instance ‘top_tb.uvm_top_tb.test_i’ (expecting datatype compatible with ‘class uvm_pkg::uvm_port_base#(.IF(class uvm_pkg::uvm_tlm_if_base#(.T1(class agent_pkg::my_transaction),.T2(class agent_pkg::my_transaction))))’ but found ‘class uvm_pkg::uvm_analysis_imp#(.T(class test::my transaction),.IMP(class test::my_scoreboard))’ instead)
Sample code:
class my_scoreboard extends uvm_scoreboard;
`uvm_component_utils(my_scoreboard)
function new(string name="my_scoreboard", uvm_component parent=null);
super.new(name,parent);
uvm_analysis_imp#(my_transaction,my_scoreboard) a_export;
a_export = new("a_export",this);
endfunction:build_phase
virtual function void write(my_transaction pkt);
I’m connecting the agent’s monitor with scoreboard’s analysis_imp in my env’s connect phase as shown below.
monitor_inst.aport.connect(scoreboard_inst.a_export);
I’m getting the type error from the above line. Please help me to identify what mistake I’m doing here.
In reply to Raj Guru:
Could you please show the declaration if yout monitor analysis port?
class my_monitor extends uvm_monitor;
`uvm_component_utils(my_monitor)
uvm_analysis_port#(my_transaction)aport;
function new(string name=“my_monitor”,uvm_component parent);
a_port = new(“aport”,this);
virutal task run_phase(uvm_phase phase);
aport.write(my_transaction);
In the monitor code you are not consistent with aport:
a_port = new("aport",this);
In the constructor you do not call
Hi chr_sue,
Thanks for the reply. a_port is a typo. Sorry!. My real issue is related to layered tb structure. Which I haven’t disclosed previously. In my tb I’m having a base monitor and driver. I’ve added the sample code below.
class monitor_base extends uvm_monitor;
`uvm_component_utils(monitor_base)
function new(string name="my_monitor",uvm_component parent);
class my_monitor extends monitor_base;
aport = new("aport",this);
//Scoreboard code
I’m connecting the ‘my_monitor’ class’s aport with ‘scoreboard’ class’s a_export. Whether this connection will cause the type error?
Please clarify this doubt.
In my_monitor you have now 2 aports, one from the base monitor and another one from my_monitor. There is no need to declare the aport twice.
I’d recommend to clean-up your code having only 1 analysis port in your monitor.
