Hi All,
I’m hitting with the follwing issue
“Type of argument ‘tmp_data__’ of virtual method ‘__m_uvm_field_automation’ in class ‘cbc_seq’ does not match with type of argument in the abstract superclass ‘uvm_rgm_sequence’”
from below shown contents of file
`ifndef CBC_SEQ__SV
`define CBC_SEQ__SV
`include "uvm_macros.svh"
import uvm_rgm_pkg::*;
`include "uvm_rgm_sequence_macros.svh" // -*- FIXME include of uvm file other than uvm_macros.svh detected, you should move to an import based methodology
// Local defines for cell.
`define WIDTH_CBC_CLK_DIV 4
`define WIDTH_SLEEP_SEL 3
`define WIDTH_WAKEUP_SEL 3
class cbc_seq extends uvm_rgm_sequence;
`uvm_object_utils_begin(cbc_seq) //bharath
`uvm_object_utils_end
`uvm_declare_p_sequencer(uvm_rgm_sequencer) //bharath
// Config settings for sequence.
integer is_pscbc_cell = 0;
integer wr_all = 1;
string cbc_cfg_reg_st;
// CBC cell register values.
rand bit clk_enable;
rand bit hw_control;
rand bit [`WIDTH_CBC_CLK_DIV-1:0] cbc_clk_divide;
// PSCBC cell settings
rand bit [`WIDTH_SLEEP_SEL-1:0] cbc_sleep_val;
rand bit [`WIDTH_WAKEUP_SEL-1:0] cbc_wakeup_val;
function new(string name="cbc_seq");
endfunction : new
// Body task for sequence
extern virtual task body();
// Set sequence values (required for executing sequence).
extern virtual function void set_sequence_values(string cbc_reg_str,
integer is_pscbc = 0,
integer wr_all_fields = 1);
endclass : cbc_seq
// body
task cbc_seq::body();
uvm_rgm_register_base m_reg_h;
`uvm_info(get_type_name(), "//:- Start CBC register sequence()", UVM_LOW);
// After randomization, update register values with new values.
// Configuration register. All fields (CBC and PSCBC) are present in register,
// so update all fields at one time.
m_reg_h = get_reg_by_name(cbc_cfg_reg_st);
m_reg_h.set_field_value ("f_clk_enable", clk_enable );
m_reg_h.set_field_value ("f_hw_ctl", hw_control );
if (wr_all == 1)
m_reg_h.set_field_value ("f_clk_div", cbc_clk_divide );
// PSCBC specific fields.
m_reg_h.set_field_value ("f_sleep", cbc_sleep_val );
m_reg_h.set_field_value ("f_wakeup", cbc_wakeup_val );
`rgm_write_send(m_reg_h)
get_response(rsp);
// Read back to make sure write has completed.
`rgm_read(m_reg_h)
get_response(rsp);
endtask : body
// set_sequence_values
function void cbc_seq::set_sequence_values(string cbc_reg_str,
cbc_cfg_reg_st = cbc_reg_str;
is_pscbc_cell = is_pscbc;
wr_all = wr_all_fields;
endfunction : set_sequence_values
`endif
I’m not getting what exactly error is poping up.
Please share your inputs to debug the error
note modeltech version using :10.5c
Thnaks,
koushik
