Hi Community,
There is a 2-input, 2 output router and I am trying to write a scoreboard for this router
My idea is based on the destination port number in the packet, whenever an input packet comes, push it to the corresponding queue(exp_q_out1/2)
The question is what if both input port1 and input port2 receives packets target at output port 1 at the same time, which write_ function will be called first. How to implement the scoreboard so it can handle such case(assuming RTL is doing round robin arbitration).
`uvm_analysis_imp_decl(_input_1)
`uvm_analysis_imp_decl(_input_2)
`uvm_analysis_imp_decl(_output_1)
`uvm_analysis_imp_decl(_output_2)
class test_scoreboard extends uvm_scoreboard;
`uvm_analysis_imp_input_1#(router_packet_t, test_scoreboard) input_port_1;
`uvm_analysis_imp_input_2#(router_packet_t, test_scoreboard) input_port_2;
`uvm_analysis_imp_output_1#(router_packet_t, test_scoreboard) output_port_1;
`uvm_analysis_imp_output_2#(router_packet_t, test_scoreboard) output_port_2;
route_packet_t exp_q_out1[$];
route_packet_t exp_q_out2[$];
virtual function void write_input_1 (router_packet_t input_packet );
case(input_packet.dst_port)
PORT_1:exp_q_out_1.push_back(input_packet);
PORT_2:exp_q_out_2.push_back(input_packet);
default: `uvm_info($sformatf("unexpected dst port number %0d", input_packet.dst_port))
endcase
virtual function void write_input_2 (router_packet_t input_packet );
endcase
virtual function void write_output_1 (router_packet_t output_packet);
router_packet_t test_packet;
if(exp_q_out_1.size())begin
test_packet = exp_q_out_1.pop_front();
output_packet.compare(test_packet);
