Two dimensional static array field registration
Hi All,
Is there a way to register a two dimensional array?
Like a one dimensional array.
 Ex....
 bit [3:0]one_dim_array[6];
 bit [3:0]two_dim_array[6][14];
`uvm_object_utils_begin(...)
   `uvm_field_sarray_int  (one_dim_array   ,UVM_ALL_ON)
   `uvm_field_sarray_int  (two_dim_array   ,UVM_ALL_ON)
`uvm_object_utils_end
 But i am facing the error in two_dim_array declartion.
 Error : An expression with an unpacked array datatype in not allowed in this context.
Thanks in Advance
Rajaraman R
In reply to Rajaraman Rak7:
Hi All,
Ex…
uvm_object_utils_begin(...) uvm_field_sarray_int (one_dim_array ,UVM_ALL_ON)
uvm_field_sarray_int (two_dim_array ,UVM_ALL_ON) uvm_object_utils_end
Thanks in Advance
Rajaraman R
Please look at this
It is highly recommended to avoid using automation macros as they can lead to major performance penalties.
HTH
In reply to rgarcia07:
More than highly recommended. There are no field macros that deal with unpacked arrays of more than one dimension.
Thanks All,
Still now i am not using more than one unpacked array.
