Guys,
An object has 100s of members, I wanted to turn of all the members from randomization except few which i’m interested in?
Is that any inbuilt mechanism to do ?
Otherwise I have to manually turn them off… using rand_mode (0)
John
Guys,
John
In reply to John Verif:
You can call randomize() with an explicit list of member variables you want randomized, ignoring the current rand_mode() settings.
See section 18.11 In-line random variable control
John,
You could use rand_mode(0) on entire object and then turn the select few ON via rand_mode(1).
Pseudo-code below;
HTH
Srini
http://www.verifworks.com
class c;
rand bit [3:0] b1, b1, b..100;
endclass : c
module m;
c c_0;
initial begin : test
c_0 = new();
c_0.rand_mode(0); // TURN OFF all
c_0.b1.rand_mode(1);
if !(c_0.randomize()...
end : test
endmodule : m
