Hello all,
Can I use TLM Port and export between monitor and scoreboard?
If interference with DUT causes an issue then, Can I avoid it by using UVM_NONBLOCKING_*_PORT?
Thank you
Hello all,
Thank you
True dave, conventional method is to use Analysis port and analysis FIFO between monitor and scoreboard but I wanted to know if we can use TLM ports(could be either blocking or non-blocking).
In reply to Harish_G:
When you are using a blocking port you might loose data. And there is another aspect. The analysis port is providing a one-to-multiple exports connection, i.e. you can connect any number of exports to the analysis port and all get the same transaction. Even 0 connections are permitted.
