TLM get and peek
Hi UVM forum,
I am trying to understand the difference between TLM get and peek.
the UVM_class_reference writes “The get interfaces are used to retrieve transactions from other components. The peek
interfaces are used for the same purpose, except the retrieved transaction is not consumed”
I am trying to write a code that demonstrates this.
class A extends uvm_component;
   `uvm_component_utils(A)
    uvm_blocking_get_imp #(pkt,A) get_imp;
    pkt t;
    event pkt_e;
    function new(...)
    task run_phase(...)
       t=...create...;
       void'(t.randomize());
       t.print();
       #10;
       -> pkt_e;
       #10;
       t.print();
   task get(output pkt t)
      @pkt_e;
      t=this.t;
endclass : A
class B extends uvm_component;
   uvm_blocking_get_port #(pkt) get_port;
   pkt t;
   task run_phase(...)
      get_port.get(t);
endclass : B
I was expected that the second t.print() in class A would fail because B already consumed the transaction.
but in the simulator I do see t printed again.
I guess I don’t understand the “is not consumed” part
Please explain
In reply to shimonc:
Since you are implementing get(), it is totally up to you to define what it means to have a transaction ready to consume, and then consume it. Typically one thinks of a FIFO or queue where get() waits for something to appear in the queue, and then pops it off.
There are two principles at play here.
The consumption you mentioned refers to a FIFO behavior of throwing away object handles once a consumer “gets” it. You don’t have a FIFO implemented. This applicable to the consumer more than the producer. If you are trying to demonstrate this point, Id put the prints in the B class, have it call get a few times (which will block), and have class A put a few random transactions into a new fifo, which gets accessed by the get() task.
As far as the print, as soon as you create() the t object, the print will never fail. You have created a class handle which has memory allocated.
I thought that UVM does something different in the background regards get and peek.
like actually delete the class property.
But now I understand that it is semantic and the implementation is up to me.
Thanks .
