Tlm fifo as shifter register
Hi all,
I’m trying to use the tlm fifo shifter register to implement a delay (like a shifter register);
in my example I’d like to have a 10 clk tick delay. What I see is that the delay works only for first 10 clock ticks.
Have anybode also tried this way? I can’t find my issue :(
Here is my code
 traffic_passive_item trans_collected, trans_collected_delay;
  uvm_analysis_port #(traffic_passive_item)     analysis_loop_port;
  uvm_tlm_analysis_fifo #(traffic_passive_item) traffic_buffer_fifo;
    super.build_phase (phase);
    trans_collected       = traffic_passive_item::type_id::create("trans_collected");
    trans_collected_delay = traffic_passive_item::type_id::create("trans_collected_delay");
    analysis_loop_port    = new("analysis_loop_port", this);
    traffic_buffer_fifo   = new ("traffic_buffer_fifo", this);
   endfunction: build_phase
            get_vif_signals();
	    buffer_data();
            send_data_to_mbox();
	  join_any
 task buffer_data();
      @(posedge vif.clk);
      if(vif.en_ck) begin
        if(vif.data_en) begin
          traffic_buffer_fifo.try_put(trans_collected);
      else
	      wr_en_debug = 1'b0;
  task send_data_to_mbox();
      @(posedge vif.clk);
      if (vif.reset_n == 1'b0) begin
        fifo_level       = 0;
      else begin
        if(vif.en_ck) begin
          fifo_level      = traffic_buffer_fifo.used();
	      if(fifo_level > 10) begin
                trans_collected_delay = new();
	        traffic_buffer_fifo.try_get(trans_collected_delay);
      	        analysis_loop_port.write(trans_collected_delay);
  task get_vif_signals();
      @(posedge vif.clk);
	 data_dut_out_1          = vif.data_1;
         data_dut_out_2          = vif.data_2;
	 trans_collected         = new();
         trans_collected.data_1  = vif.data_1;
         trans_collected.data_2  = vif.data_2;
thanks to all
In reply to alexkidd84:
Unfortunately I do not really understand why you need 10 clock cycles delay. Transactions are intended for use in transaction-level-modelling. On the transaction level you do not think in terms of clock cycles There is only the order of transactions important. When you need a transaction for further processing you can perform a get on a tlm_fifo and you’ll get it when there is one.
It would really help to explain what your code does after 10 clock cycles since we cannot run it ourselves.
I think this code is a lot more complicated than it needs to be. First, I would have used a simple queue instead of a tlm_fifo.
Next, the way you have structured your fork/join_any(which should be a simple fork/join) creates a few race conditions. There is a race between the traffic_buffer_fifo.try_put and traffic_buffer_fifo.try_get, and there is a race between the
and
I would not do the
fork[/fork] at all, or you need to add non-blocking assignments to remove the races.
Also, there is never a need to construct trans_collected_delay; you do both a create() and a new() unnecessarily.
Finally, you have
if (reset_n==0) fifo_level = 0;
which is unnecessary as well.
thanks dave, i refactored and rearranged my code and now it works.
