Hi, I had a issue with interface type override. Let me explain what I'm trying. I had a parameterized base class which contain a virtual interface declaration. I extended one more parameterized class from base and used the factory override to override the agent class. In the run time, the issue I am seeing that, the data type of the virtual interface is not chanTed. However I can see the override object is created. When the agent is trying to get from resource db, I am seeing data type of virtual interface as like in base but not like as in override type. Is there any solution how to fetch a virtual interface with the override type. The override type is used to pass different parameters and factory override is used to overriding. I know once solution is instantiate a object for override agent and no need of factory override. Here already a infrastructure is build I would no like to disturb this.
