for example I have a item like below.
class my_trans extend uvm_sequence_item;
bit active;
logic [9:0] addr;
logic [31:0] data;
`uvm_object_utils_begin(my_trans)
`uvm_field_int(active, UVM_ALL_ON)
`uvm_field_int(addr, UVM_ALL_ON)
`uvm_field_int(data, UVM_ALL_ON)
`uvm_object_utils_end
Is there any function to print each members of this 'my_trans' ? I mean the output of this function would be like below.
active addr data
Thank you for any help !
