Hi All,
I got below error. What is causing this error. I am using two seq. with same sequence item.
syntax error, unexpected type name. The type ‘nvx_aes_mtu_in_seq_item’ is defined at /pkgs/nvx_aes_mtu_in_seq_item.sv
class nvx_aes_mtu_in_seq extends nvx_aes_base_seq #(
.SEQ_ITEM_T(nvx_aes_mtu_in_seq_item)
class nvx_aes_mtu_in_spec_seq extends nvx_aes_base_seq #(
Here it is complaining
task nvx_aes_mtu_in_spec_seq::body()
nvx_aes_mtu_in_seq_item req, rsp;
nvx_aes_cfg m_cfg;
bit decrypt;
In another sequence, i am calling both of sequence,
mtu_in_seq = nvx_aes_mtu_in_seq::type_id::create(“mtu_in_seq”);
mtu_out_seq = nvx_aes_mtu_out_seq::type_id::create(“mtu_out_seq”);
mtu_in_spec_seq = nvx_aes_mtu_in_spec_seq::type_id::create(“mtu_in_spec_seq”);
Nainesh
