i dont find any syntax error here but its showing something like this
Error-[SE] Syntax error
“dpram_test.sv”, 7: token is ‘dpram_base_test’
class dpram_test extends dpram_base_test;
The following EDA playground link of that
Edit, save, simulate, synthesize SystemVerilog, Verilog, VHDL and other HDLs from your web browser.
In reply to yethishwar :
Hi Yesthiswhar,
It seems the file containing the base class ‘dpram_base_test’ is not compiled before dpram_test.sv.
You need to order the files rightly for compilation.
Prem
It means, your dpram_test.sv doesn’t see dpram_base_test class. Please include dpram_base_test file to dpram_test.sv file.
`include "dpram_base_test.sv"
This is simple error. Please try to self-debug the problem first, before asking the solution.
In reply to chris_le :
Thank you sir for your advice .I debugged it before posting the question .but as i am new to this field , i was unable to identify the error .
