Syncronous RAM
Hi All,
How do i make checker for synchronous memory in UVM environment?
In reply to Mukund Sojitra:
What do you want to check? This is the key question.
Hi All,
Have you thought of putting the checker in an interface? Below is code for an example extracted from my SVA Handbook 4th Edition; it may help you as a guide or as ideas.
If you need the checker to be within a task, consider using tasks for your assertions; see PAPER: Understanding the SVA Engine + Simple alternate solutions - SystemVerilog - Verification Academy
module memory_data_integrity_check (
    input bit write, // memory write
    input bit read,  // memory read
    input bit[31:0] wdata, // data written to memory
    input bit[31:0]  addr,  // memory address -- small for simulation
    input bit reset_n, // active low reset
    input bit clk);   // clock
    timeunit 1ns;   timeprecision 100ps;
    default clocking cb_clk @ (posedge clk);  endclocking
    int mem_aarray[*]; // associative array (AA) to be used by property
    bit [31:0] rdata;  // data read from memory
    bit  mem_aarray_exists;  // exists at specified address
    assign mem_aarray_exists  = mem_aarray.exists(addr);
    always_comb
        if(mem_aarray_exists)
            rdata  = mem_aarray[addr];  //
    always@ (posedge clk)
        if (reset_n==1'b0) mem_aarray.delete; // Clears AA elements
        else if (write) mem_aarray[addr]  = wdata; // store data
    property p_read_after_write;
        bit [31:0] v_wrdata, v_wraddr;
        (write, v_wraddr=addr, v_wrdata= wdata) |-> // if write, save data and addr
        (read && mem_aarray_exists && addr==v_wraddr) [->1] |-> // @read and data there at same written addr
        rdata==v_wrdata;  // read data is same as what was written
    endproperty : p_read_after_write
    ap_read_after_write : assert property (p_read_after_write)
        $info("addr =%h, rdata=%h", $sampled(addr), $sampled(rdata)); else
        $error("addr =%h, rdata=%h", $sampled(addr), $sampled(rdata));
    property p_read_before_write;
        not (read && !mem_aarray_exists); // never a read on an non written address
    endproperty : p_read_before_write
    ap_read_before_write : assert property (p_read_before_write);
endmodule : memory_data_integrity_check
class c_xactn;
    rand bit write; // memory write
    rand bit read;  // memory read
    rand int wdata; // data written to memory
    rand bit[31:0] addr;  // memory address
    constraint addr_range_cst { addr <= 15 ;}
    constraint no_wr_and_rd_cst { !(read && write);}
endclass : c_xactn
module top;
    int rdata; // data read from memory
    bit reset_n=1'b1; // active low reset
    bit clk=1'b1;   // clock
    c_xactn c1=new();
    memory_data_integrity_check mem_check1 (.*);
    initial forever #50 clk=!clk;
    always_ff @ (posedge clk) begin
        if(!c1.randomize())  $error("c1 randomization failure");
        write <= c1.write;
        read  <= c1.read;
        wdata <= c1.wdata;
        addr  <= c1.addr;
endmodule : top
Ben Cohen
http://www.systemverilog.us/ ben@systemverilog.us
For training, consulting, services: contact Home - My cvcblr
Hi ben,
thank you very much for your kind help.
Hi,chr_sue
I don’t know what to check .
You please suggest me.
Hi,chr_sue
I don’t know what to check.
Your original post was How do i make checker for synchronous memory ?
I presumed that what you meant was:
  • I have a large memory.
  • I need to check that it works, meaning that what I read is indeed what I wrote. The model I gave you does that.
  • What are your requirements? Access speed? Size? Refresh rate (if dynamic mem), …
    YOU need to specify what you want.
Sorry to be so blunt, but I don’t know what to check. sounds more like I don’t know what I want, I need, and what the hell I am doing. I don’t know my requirements Not a good starting point to “what to check”. You better do better than that.
Please, don’t take offense, but people who know me *and I provided many reviews, papers and books)*understand that I tend to be very blunt and straight in my comments.
Ben SystemVerilog.us
Hi Ben,
Thanks for guiding me. I want do protocol checking that whatever data i am writing in memory is actually written or not?
Then write assertions (In SVA (if in interface or module or SV checker) or in tasks (if within a class)) that check for the protocol interfaces. You may also use associative array, as described in my model to emulate a very large memory. You should have a document that defines the protocol requirements. Assertions basically check that the requirements are met, based on those requirement documents, and not on the implementation, obviously.
Thank you.
