is there any difference when clock for an interface is defined through interface parameter versus when it is a part of interface signals, like the one below:
interface DUT_intf ();
logic clock;
endinterface
interface DUT_intf (input clock);
endinterface
In reply to verif_learner:
The difference is whether you want the interface to have an independent clock, or share the signal from some other source that you connect to the interface port. BTW, the proper terminology is port — a parameter means something else in SystemVerilog.
Thanks. I am not clear what you mean by independent clock vs share the signal.
An example will help.
Interface ports work the same as module ports — they make connections. In the example below, top.i1.clock, top.i2.clock, and top.i3.clock always have the same value driven by top.clk.
interface DUT_intf (input bit clock);
endinterface
module top;
bit clk;
DUT_intf i1(clk);
DUT_intf i2(clk);
DUT_intf i3(clk);
In the example below, top.i1.clock, top.i2.clock, and top.i3.clock may be driven independently.
bit clock...
endinterface
module top;
bit clk;
DUT_intf i1();
DUT_intf i2();
DUT_intf i3();
