SV and vhdl Dut connection
In uvm environment I want connect .sv(TB) and design in vhdl. How to represent record under record in systemverilog struct?
 type abc_t is
  record
  valid  :std_logic
  data : std_logic_vector(7 downto 0);
  end record;
  type a is array (5 downto 0) of abc_t;
  type b is array (3 downto 0) of a;
  type bcd_t is
   record
    efg : b
   end record;
How to represent above code in system verilog?
In reply to poonamnlwd:
Please use code tags making your code easier to read. I have added them for you.
There is no standard that defines the interaction between VHDL and SystemVerilog, although most simulation tools provide methods to connect the two. You will need to refer to your tool documentation or contact your tool vendor for additional assistance.
type abc_t is
record
valid  :std_logic
end record;
type bcd_t is
record
efg : b
end record;
You could do it like this:
package my_sv_types;
typedef struct packed {
     logic val;
     logic [7:0] dat;
     } abc_sv_t;
typedef abc_sv_t [5:0] a;
typedef a [3:0] b;
     b efg;
    } bcd_sv_t;
endpackage
typedef struct {
  bit val;
  bit [7:0] data;
}abc_t;
typedef abc_t a[6];
typedef a b[4];
typedef struct {
  b efg;
}bcd_sv_t
5 downto 0 is considered as a width or depth?
This does not matter. See the code example below.
     logic val;
     logic [7:0] dat;
     } abc_sv_t;
typedef abc_sv_t [6] a;
typedef a [4] b;
     b efg;
    } bcd_sv_t;
endpackage
module tb;
  import my_sv_types::*;
  logic clk;
  a     sig1 = '{'{1'b0, 8'h55}, '{1'b0, 8'h55}, '{1'b0, 8'h55}, '{1'b0, 8'h55}, '{1'b0, 8'h55}, '{1'b0, 8'h55}};
  b     sig2;
  abc_sv_t [5:0] sig3;
  bcd_sv_t [3:0] sig4;
  abc_sv_t [0:5] sig5;
  bcd_sv_t [0:3] sig6;
    sig3 = sig1;
    #10;
    sig5 = sig1;
    #10;
Thank you for an example
