Super.build_phase(phase ) usage issue
Dear All,
I’m trying to understand uvm_agent class, I’ve got 2 example about uvm_agent as the below.
the below is UVM-genden reference guide example.
class example_agent extends uvm_agent;
      example_sequencer #(example_transaction) m_sequencer ;
      example_driver m_driver ;
      example_monitor m_monitor ;
      uvm_analysis_port # (example_transaction) monitor_ap ;
      virtual dut_if v_dut_if;
      virtual function void build_phase (uvm_phase phase) ;
            super.build_phase(phase ) ;   //<--------------------------------------- HERE
            m_monitor = example_monitor::type_id::create("m_monitor", this);
            monitor_ap = new("monitor_ap", this) ;
            if ( get_is_active() == UVM_ACTIVE ) begin
                m_sequencer = example_sequencer::type_id::create("m_sequencer", this);
                m_driver = example_driver::type_id::create("m_driver", this);
      endfunction : build_phase
      virtual function void connect_phase (uvm_phase phase);
            m_monítor.monitor_ap.connect(monitor_ap ) ;
           if ( get_is_active() == UVM_ACTTVE ) begin
               m_drÍver.seq_item_port.connect(m_sequencer.seq_item_export) ;
      endfunction : connect_phase
endclass :
The below is Hello UVM example. UVM Hello World - EDA Playground
package my_testbench_pkg;
  // The UVM sequence, transaction item, and driver are in these files:
  `include "my_sequence.svh"
  `include "my_driver.svh"
  // The agent contains sequencer, driver, and monitor (not included)
  class my_agent extends uvm_agent;
    `uvm_component_utils(my_agent)
    my_driver driver;
    uvm_sequencer#(my_transaction) sequencer;
      super.build_phase(phase ); //<---------------------------I add this for test.
      driver = my_driver ::type_id::create("driver", this);
      sequencer =
        uvm_sequencer#(my_transaction)::type_id::create("sequencer", this);
I’ve got the below error messages as the below, when I add “super.build_phase(phase );”
I just follow test1 example code.
ncvlog: E,NOTCLM (my_testbench_pkg.svh,20|22): build_phase is not a class item.
(`include file: my_testbench_pkg.svh line 84, file: testbench.sv line 9)
import my_testbench_pkg::
I can’t understand why does error happen? I can’t understand this problem.
In reply to UVM_LOVE:
What do you mean super.bui1d_phase? We dont have any method bui1d_phase, we only have build_phase.
My guess is you have confused super.build_phase with super.bui1d_phase. Also I see you have written “virtuaf” instead of “virtual” (Although that could be an issue on my end only).
I have corrected (most of) your code so you may wanna reconsider:
By calling super.build_phase(phase) you are actually calling the build phase of the parent class from which your class has been extended (in this case, the parent class would be uvm_agent) and hence you are calling the build_phase of uvm_agent file (that is stored somewhere in a file as a part of the uvm methodology source file package)
    my_driver driver;
      sequencer =
In reply to Vedant Gala:
Sorry for my typo. I just copy the pdf text but it makes some typo.
I’ve fit it.
I’m confused that the upper example code used with super keyword.
so I add super keyword at second example code but it makes some error.
Did I make some mistake?
In reply to chris_le:
Sorry for my typo, I’ve fixed it.
The super keyword basically refers to the parent class. (Read more on Class Hierarchy, if unaware). Somewhere in the UVM file directory there is a file uvm_agent, which has a function build_phase too; and so when you include this line in your code
You are basically calling that function inside uvm_agent class.
Why only uvm_agent? Because in your example, the class example_agent extends from uvm_agent.
Correct the typo bui1d_phase and then check for errors.
Also you must have an ‘endclass’ at the end
Thanks for letting me know that. I agree that the super keyword basically refers to the parent class.
So If I use “super.build_phase(phase);” means that I will use the parent class’s item(in this case, it will be “uvm_agent” class, and we assume that build_phase method will be there in uvm_agent class, am I right? )
ncvlog: *E,NOTCLM (my_testbench_pkg.svh,20|22): build_phase is not a class item.
But I didn’t get it exactly what build_phase is not a class item. doesn’t it make sense?
ans also what if the build_phase is not a class item, then what is it?
build_phase is a class method of the class uvm_agent in your case, but it is not a data member of uvm_agent. In general it is the build_phase of one of the bas classes contained in the UVM library.
In your code example there might be something wrong, like a missing semicolon, because your error message is pointing to the wrong place.
You have a typo somewhere and unless you can post the exact code you are running, we can’t help you. The task build_phase is in your uvm_component base class if everything was enter correctly.
There no need to call super.build_phase() unless you are using the UVM field macros, which we recommend strongly against because of the performance penalties.
Also, please see this comment about parent/child terminology. This is especially pertinent when talking about uvm_component.
Thanks for replying that. I found a fault point as your recommends.
Would you please let me know the list what you strongly recommends like thjs case?
https://verificationacademy.com/forums/uvm/field-automation-macros#reply-39244
Hi Dave,
Could you please elaborate on why the super.build_phase() is not needed?
-R
In reply to rgarcia07:
Hi Dave,
-R
Because is does nothing for you other than waste CPU time. If you used the UVM field macros, then you must call super.build() and you will waste a lot of CPU time.
