Hi ,
I have defined class user_item that would be used in RAL TB setup .
Currently I am confused whether to extend it from uvm_sequence_item OR uvm_reg_item ( which itself extends uvm_sequence_item )
The class user_item would be used in following cases ::
(1) As specialization of uvm_reg_sequence .
By default ::
class uvm_reg_sequence extends uvm_sequence #( uvm_reg_item ) ;
User could also specialize to user_item ( which extends uvm_sequence_item ) which is then used as specialization of uvm_sequence .
Eg : class my_reg_seq #( type BASE = uvm_sequence#( user_item ) ) extends uvm_reg_sequence #( BASE );
(2) As actual return type of function ’ reg2bus ’ .
virtual function uvm_sequence_item reg2bus(const ref uvm_reg_bus_op rw);
user_item bus_item ;
bus_item = user_item :: type_id :: create( "bus_item" ) ;
// Assign properties of bus_item based on input argument rw
return bus_item ; // Actual return type
Within adapter function ' reg2bus ' the actual return type Must be extended type of uvm_sequence_item
which then the UVM library passes to start_item N finish_item .
(3) Within predictor ::
(a) Type parameter BUSTYPE receives bus transactions from monitor .
(b) Analysis Port specialized to uvm_reg_item is used to broadcast transactions received .
[Q] Should I define class user_item to extend uvm_sequence_item OR uvm_reg_item
Only for the analysis_port within uvm_reg_predictor there is requirement of Specialization of uvm_reg_item .
In other cases ( (1) , (2) , (3)(a) ) I could simply extend from uvm_sequence_item .
**Are there any additional advantages if I were to extend from uvm_reg_item ?**
