Hello. I’m new in UVM so I have a task to do a test ,which should do the following:
1-Running a sequence with hyperframes
2-Asserting the reset in the middle of the process and disabling the reference model of the DUT which I’m testing
3-After some delay, De-asserting the reset and starting the same sequence
How should I do this? I’ve tried to interrupt the sequence with fork-join_any:
env.seq.start(env.sequencer)
When I de-asserted and needed to run the sequence again is comes with an error that the sequencer is still running. I’ve tried with env.seq.kill method after the join_any ,but again didn’t worked out. Is there any way to stop the sequencer or something else? Thanks in advance
Stopping sequnces might not be the recommended way in sequnce execution. The sequnce should come to its end. If you replace your join_any by join it should work.
BTW I’m a litlle bit confused where you have your sequence. It should be started in your test and not in your env.
Yes ,but the problem is that I’ve configured number of frames to be 20 for example. If I let them transmit on the first stage, there will be no traffic after the de-assertion of the reset. And the other thing is that I need to see if the registers are reseting properly in a case of unplanned reset (like this one). There is no point of replacing join_any with join ,because I don’t want to let the sequence to finish. My idea is to let for example 6-7 frames till the delay, reseting and then either continue with the others or start over again.
OK, I understood. But you should never start a sequence from your environment. You should always run a test and the test starts your sequence. One of the main ideas and benefits of thhe UVM is the seperation from test and testbench. The env is your testbench. The test configures your testbench to your needs and starts the test.
OK. I see.
If you are using get_next_item you need always an item_done.
If you call e simple get you do not need to call anything. Only in case you wanat to give back a response you can call put.
