Is there a way to stop and restarts assertions from the uvm sequence.
I have a testbench requirement where in the middle of a sequence there is a dirty period,where the assertions are expected to fail. I want to disable
all the assertions (under testbench heirarchy) during this dirty period and enable it again after this dirty period is over.
I tried adding following in my sequence, but it gave error
$assertoff(1,uvm_test_top.testbench);
$assertoff(1,testbench);
*The name (‘uvm_test_top.testbench’) was not found in the current scope. Please verify the spelling of the name ‘uvm_test_top.testbench’
** Error (suppressible): …/…/…/…/verification/testcases/sequences/axi_rgm_seq_lib_hdmi_2_1_b2b.sv(8943): (vlog-7027) The name (‘testbench’) was not found in the current scope. Please verify the spelling of the name ‘testbench’.*
Could you please advice on what should be my approach for this requirement.
Thanks in Advance.
