Hello all,
I’m wondering how I can start test so tb components will proceed to run phase when it comes to a reactive agent.
In reply to abdelaali_21:
Your question does not make much sense. Something has to be “active” in order to have “reactive” behavior.
Hey dave,
My agent is a slave agent, so it runs a sequence forever waiting for a request from dut (master) then generates corresponding response. My question is, in test level, how the test will be started ? So all tb components proceed to run phase.
I hope i make it clearer now
You cannot run a test with a reactive slave only. You have to stimulate your DUT actively using an active agent with sequencer/driver. You are starting your test which executes at least 1 sequence to stimulate your DUT. The reactive slave is now waiting for an indication to become active.
Do i need to create a master agent for my dut (master) in order to verify a reactive agent?
You do not show what you want to verify. But using a reactive agent needs another active agent. The active agentt is stimulating your DUT.
Thanks for your reply,
To sum up, if i want to verify a dut(master) that has say ahb master interface, i need to have an ahb_master agent and ahb_slave agent in my uvm testbench. Did i got what you meant?
if so, how i can connect ahb master agent signals and ahb slave agent signals in tb top ?
I looked for a uvm salve enviroment architecture but could’nt find any. just to see what the architecture is like when verifying master.
Yes, because your DUT is not working automatically. It has to be stimulated from somewhere.
