SO I am trying to solve something without the using the constraint keyword. The question is , how would you generate the following 5 <= a+b <= 10 WITHOUT using constraint but you are allowed to use $urandom etc ? Any ideas?
In reply to zuzamen:
Two ideas
- generate random numbers for A and B repeatedly stoping when you get values that meet your constraint.
- Build your own constraint solver, e.g. What’s behind Wolfram Alpha.
Your requirement can be achieved with following code, but i don’t know it as per the guideline or not.
int a,b;
int min = 5;
int max = 10;
while(!((a+b) inside {[min:max]}))
a = $urandom_range(1,(max-1));
b = $urandom_range(1,(max-1));
Regards,
Mitesh Patel
