forever
if (!APB.PRESETn) begin
APB.PREADY = 1’b0;
APB.PSLVERR = 1’b0;
@(posedge APB.PCLK);
else begin
// Setup Phase
// Setup phase activity
seq_item_port.item_done(); **//SHOULD BE seq_item_port.item_done(req); ??**
// Access Phase
seq_item_port.get_next_item(rsp);
// Access phase activity
Driver first copies wdata, addr, rw into ‘req’ in setup phase, then driver calls item_done(). The change in ‘req’ inside driver, automatically reflects in ‘req’ inside sequence after finish_item, so no need to use get_response in sequence or item_done(req) in driver.
Also for ‘rsp’ inside sequence, driver just needs rdata (if !rw), slverr and delay, so sequence just send them in ‘rsp’. Driver knows that after item_done() of setup phase, again calling get_next_item(rsp) in access phase, will have all those response things(rdata, slverr, delay) which it need to drive at pin level in access phase.
In my requirement in the below example
i am collecting request from my driver ( logic in driver which collect and stores in queue and pushes to req)
task apb_slave_sequence::body;
apb_slave_agent_config m_cfg = apb_slave_agent_config::get_config(m_sequencer);
apb_slave_seq_item req;
apb_slave_seq_item rsp;
wait (m_cfg.APB.PRESETn);
req = apb_slave_seq_item::type_id::create("req");
rsp = apb_slave_seq_item::type_id::create("rsp");
// Slave request:
start_item(req);
finish_item(req);
// Slave response:
if (req.rw) begin
memory[req.addr] = req.wdata;
start_item(rsp);
rsp.copy(req);
assert (rsp.randomize() with {if(!rsp.rw) rsp.rdata == memory[rsp.addr];});
finish_item(rsp);
endtask:body
i am using this sequence in my vertual sequence and sending via virtual sequencer.
class my_virual_sequence extends uvm_sequence;
task body();
first_seq.start(p_sequencer.my_firstseqr)
copy_apb_slave_sequenc.start (p_sequencer.my_apb_seqr);
//here i want to collect the transaction (req) and decode
//Drive response packet
Question : How to collect the req from my sequence to virtual sequence
