sunils
February 16, 2017, 11:44am
1
Hello Forum,
I am verifying simple dut with uvm-1.1d and Questasim-10.2b. In the simulation it shows the following error:
# UVM_INFO @ 0: reporter [RNTST] Running test test...
# UVM_INFO test.sv(20) @ 0: uvm_test_top [addition test]
# Name Type Size Value
# mseq my_sequence - @720
# knob integral 32 'h19
# req object - <null>
# rsp object - <null>
# UVM_INFO verilog_src/uvm-1.1d/src/base/uvm_objection.svh(1268) @ 52400: reporter [TEST_DONE] 'run' phase is ready to proceed to the 'extract' phase
Can you please help in this regard, what can be the possible reason.
Thanks and Regards
Sunil S.
chr_sue
February 16, 2017, 1:08pm
2
In reply to sunils :
This means there is neither a req created nor a rsp. Which might be a consequence of the non-existing req.
cgales
February 16, 2017, 1:09pm
3
This isn’t an error. A sequence defines the variables ‘req’ and ‘rsp’ of the type that the sequence was typed with. It looks like you didn’t use these variables, so they are null.
sunils
February 16, 2017, 5:12pm
4
In reply to cgales :
Hello Cgales,
From the above simulation view, when test start running, it only print that(only one name type size and value) and collect to extract phase.
I am doubting why it is not able to proceed further. Please suggest some possible reasons.
Thanks and Regards
Sunil S.
chr_sue
February 16, 2017, 6:33pm
5
Hi sunil did you implement the objection mechanism? It looks like there is no objection raised.
