In my experience, the tools use a deterministic algorithm to generate those numbers. However you can’t actually rely on that being the same from one sim to the next, as any number of little things could slightly perturb the algorithm ( it’s undocumented ).
On the other hand, during the course of a single simulation, that number should be constant for a given object. So,
Klass k = new;
Klass j = new;
Klass i = new;
$write( "k=@%0d, j=@%0d, i=@%0d\n", k, j, i );
Will print something like:
[pre]k=@1, j=@2, i=@3[/pre]
And the same number for those objects, should print for the remainder of the simulation. This is a big assumption on my part. I haven’t seen an SV LRM requirement that requires that. But I’ve used multiple simulators, and so far that’s the behavior I’ve seen.
@warnerrs, you’re right in your observation but wrong in your conclusion :-). It is not the tools that generate these numbers but UVM itself. The number is a UVM object instance id, accessible via the uvm_object::get_inst_id(). For every uvm_object that UVM creates, it increments the ID. Therefore it will remain constant as long at you don’t change either your code (creating new objects, changing the order of creation), or your simulator (which might trigger changes to order of execution anyway).
@avidan, I never traced back to the source of those numbers, but I noticed they behaved just like my example $write() statement. Thanks for that detail, thanks makes a lot of sense.
