Simple but complete UVM example
Hi to All,
I’m novice to the SV methodology world and would like to try out few example code of UVM.
I tried to work thru the UVM_1.1 UBUS example bundle but I find it too difficult to understand and
get hang of various constructs used.
Is there a better & user friendly example available anywhere which I can use a reference for all my
future projects on SV-UVM?
Failed to get a complete example by googling and hence I think this forum is the right place to get this answer.
/Sachin
Hi Sachin
You can refer the example on Simple UVM Testbench - EDA Playground
Also UVM Guide for Beginners – Pedro Araújo & UVM – ClueLogic
Hope this would get you started, may be you can also refer to WWW.TESTBENCH.IN - Easy Labs : UVM
-BR
Hash
The UVM Cookbook has many small examples with documentation explaining each example. Code Example Downloads | Verification Academy
In reply to Hash:
Thanks Alot for the data.
There are the two best approaches to starting with the smallest UVM Reference Design:
Start by implementing a very simple UVM testbench with a simple COUNTER DUT or MEMORY DUT.
Follow these two procedures:
  1. Basic UVM | Universal Verification Methodology | Verification Academy
  2. UVM Framework | Verification Academy
Here is an excellent detailed description of the Minimum UVM Code Templates (of Classes, Methods, Macros) required to implement UVM:
https://verificationacademy.com/sessions/dvcon-2015/paper-presentation/UVM-Rapid-Adoption-A-Practical-Subset-of-UVM
