Dear All,
I’m confused that the declaration of reg_model implementation.
and I want to know what is the difference if I don’t implement reg_model at env hierarchy.
For example,
uart_ctrl_tb.sv
class uart_ctrl_tb extends uvm_env
uart_ctrl_env uart_ctrl0
// declare register model
uart_ctrl_reg_model_c reg_model //<-------Here reg_model declared
uart_ctrl_env.sv
class uart_ctrl_env extends uvm_env
uart_ctrl_reg_model_c reg model; //<-------Here reg_model declared also too.
`uvm_component_utils_begin(uart_strl_env)
`uvm_field_object(reg_model, UVM_DEFAULT);
`uvm_component_utils_end
From here, If I do comment out the reg_model as the below,
Is it possible way? I mean the former way is twice declared the reg_model.
It seems that redundant so I want to comment the reg_model.
Is there any special reason the reason is declared at the both side tb and env?
uart_ctrl_env.sv
//uart_ctrl_reg_model_c reg model;
// `uvm_field_object(reg_model, UVM_DEFAULT);
