Set_type_override_by_type
I am getting an error while running the following code on EDA Playground. Can anyone help me resolve. Thanks.
`include "pkg.sv"
import pkg::*;
module top();
  write_xtn w_h;
  function void build();
    w_h=write_xtn::type_id::create("w_h");
    w_h.randomize;
    w_h.print();
  initial
    for(int i=0;i<5;i=i+1)
    build();
	factory.set_type_override_by_type (write_xtn::get_type(),short_xtn::get_type());
    //set_type_override_by_type(write_xtn::get_type(),short_xtn::get_type());
    build();
Error Details
Error-[XMRE] Cross-module reference resolution error
testbench.sv, 20
Error found while trying to resolve cross-module reference.
token ‘factory’. Originating module ‘top’.
Source info: factory.set_type_override_by_type(write_xtn::get_type(),
In reply to Abijith Prakash:
Is this your code? There are a few weaknesses:
(1) Why to include the file pkg.sv?
(2) There is no object of the factory (see your override command)
You can either use
uvm_factory factory = uvm_coreservice_t::get().get_factory();
OR
set_type_override(write_xtn::get_type(),short_xtn::get_type());
this was the code from my training school. I have just tried to redo it on EDA playground using synopsys VCS simulator.
pkg.sv includes the other files of TB. I have just included the top module above.
OK, but the module does not know the factory. You have the declare this.
And what is in the package pkg you are importing?
package pkg;
`include “uvm_macros.svh”
include "tb_defs.sv" include “write_xtn.sv”
`include “short_xtn.sv”
endpackage
I am including and importing the package because i was getting an error in EDA playground.
It looks like you are including and importing the same. Right?
Yes.
I declared the handle factory and used factory = uvm_coreservice_t::get().get_factory();. It worked. Thanks.
In reply to amansoor:
Thanks for the response.
