I am trying to set values in my test class to different env instances using uvm_config_db.
But the output is coming as 0 for both instances.
The code is quoted below. What changes do I have to make to get expected output ?
Obsreved output is,
**# UVM_INFO @ 0: reporter [RNTST] Running test test…
UVM_INFO .\db_problem.sv(23) @ 0: uvm_test_top.ENV1 [ENV1] VALUE = 0
UVM_INFO .\db_problem.sv(23) @ 0: uvm_test_top.ENV2 [ENV2] VALUE = 0**
Expected output is,
UVM_INFO .\db_problem.sv(23) @ 0: uvm_test_top.ENV1 [ENV1] VALUE = 10
UVM_INFO .\db_problem.sv(23) @ 0: uvm_test_top.ENV2 [ENV2] VALUE = 20**
`include "uvm_macros.svh"
class env extends uvm_env;
`uvm_component_utils(env)
endfunction //new()
int value;
uvm_config_db#(int) :: get(this,"","value",value);
`uvm_info(get_name(), $sformatf("VALUE = %d", value), UVM_NONE)
endclass //env
class test extends uvm_test;
`uvm_component_utils(test)
endfunction //new()
env E1,E2;
E1 = env::type_id::create("ENV1",this);
E2 = env::type_id::create("ENV2",this);
//Setting value = 10 for env1 E1
uvm_config_db#(int) :: set(this,".E1","value",10);
//Setting value = 20 for env2 E2
uvm_config_db#(int) :: set(this,".E2","value",20);
endclass //agent2 extends uvm_agent
module tb;
run_test("test");
