I am trying to demote UVM_WARNING to UVM_INFO for one of my test cases using set_report_severity_id_override, but it is not working.
In the build phase of the test case, I have added the following lines:
Which phase you do this in is only part of the problem. Classes derived from uvm_component are also derived from uvm_report_object. That means they can have independent set_report_ settings. So you have to apply the setting to the specific component object. You can do this from your test either using a handle the component:
m_env.m_agent.m_driver.set_report_...(...);
or you can apply it to the entire component hierarchy (from the component where the function gets called)
set_report_..._hier(...);
In both cases, these function call must be made after constructing the component you want to target. That will be any phase after the build_phase.
