Set function is not updating desired value of uvm_reg_field with access "W1T"
I have a 32 register with 3 fields.
Field a → Bit [1:0] → “RW”
Field b → Bit [5:2] → “W1T”
Field c → Bit [31:6] → “RO”
The initial value of register is 32’h0 and I am setting the desired value with 32’h8741_256a.
The expected value with get function is 32’h0000_002a but I am receiving 32’h0000_0002.
In reply to kishore_tavva:
The access type W1T does not belong to the default access types. You have to enable it explicitly.
Hi Chr_sue,
In the register definition, for field ‘b’, I have explicitly defined the access as “W1T”.
I understand, but not all possible access types are supported automatically by the RAL layer. You have to enable some of these specific types.
Hi Chr_sue,
Could you please help me on how to enable “W1T” access for field ‘b’.
You have to call ‘set_access(string mode)’ on the specific reg_field where mode is your access mode like this
your_reg_field.aet_access(“W1T”);
