Sequences in fork...join_none
Hi all,
in testcase i have called sequences , but which is not working as per expecations, can anyone helpme in telling where I am going worng ?
phase.rasie_objections();
 for(int k=0;k<4;k++) begin
  @(posedge clk[k]_in) if(enable[k]==1) begin
       cap_seq[k].start(env.agent[k].seqr);
  join_none
wait fork;
phase.drop_objections();
In reply to rohit_kumar:
It always helps to explain what your expectations are versus what you see happening, especially when you have provided so little code.
See this post for a possible problem.
Hi Dave,
as soon as enable is high, the 4 sequences should start parallel at the next posedge clk available, but in this case the sequence is not starting, even though enable is high. I do know where i am going worng, please let me know …
phase.raise_objections();
   env_h.reg_blk.enable.set(4'b1111);
   env_h.reg_blk.update(.path(UVM_FRONTDOOR),.parent(null),.status(status)));
     automatic int j = k;
        @(posedge clk[j]_in) if(enable[j]==1) begin
           cap_seq[j].start(env.agent[j].seqr);
      join_none
    wait fork;
join
Not sure what you mean by
clk[j]_in
. Perhaps you meant
clk_in[j]
Once that is fixed, your code does not wait for
enable
to be high; it only checks it once on the first clock cycle. You probably want
  @(posedge clk_in[k] iff (enable[k]==1)) begin
Thanks Dave :)
regarding clk ya it was typo error. after using “iff” it worked, but can you explain why the earlier code with
was not working.
was not working.
Because it only checks enable[j] once at the first clock cycle and the process terminates after that.
got it
Thank you Dave :)
