class ahb_slave_write_wait_seq extends ahb_slave_sequence_base;
//uvm factory registery
`uvm_object_utils(ahb_slave_write_wait_seq)
//semaphore for multi-thread
semaphore phase_lock = new(1);
//uvm standard method: new
function new(string name = "ahb_slave_write_wait_seq");
//user define method: beat_transfer
virtual task beat_transfer();
ahb_slave_item req;
ahb_slave_item rsp;
req = new();
rsp = new();
phase_lock.get(); //get the key
`uvm_info(get_name(), $sformatf("slave start_item"), UVM_HIGH);
//get request
start_item(req);
assert(req.randomize() with{req.hresp == 2'b00;});
`uvm_info(get_name(), $sformatf("req.hready_low_cycle is %0d", req.hready_low_cycle), UVM_HIGH);
finish_item(req);
`uvm_info(get_name(), $sformatf("slave finish_item"), UVM_HIGH);
phase_lock.put(); //put back the key
//put response
start_item(rsp);
rsp.my_copy(req);
if(rsp.hresp == 2'b00) begin //when slave agent response is OKAY, load wdata to memory
if(rsp.cmd) begin
memory[req.addr] = req.wdata;
else begin
if(!memory.exists(rsp.addr)) begin
memory[rsp.addr] = 32'heeeeffff;
assert(rsp.randomize() with {rsp.rdata == memory[rsp.addr];});
`uvm_info(get_name(), $sformatf("rsp.hready_low_cycle is %0d", rsp.hready_low_cycle), UVM_HIGH);
finish_item(rsp);
//uvm standard method: body
virtual task body();
//multi-thread
beat_transfer();
beat_transfer();
join
endtask;
//:ts=4,sw=4
During simulation,i got a log below:
uvm_fatal:Sequencer send_request not able to put to fifo, depth 1
I don’t know why m_req_fifo.size() = 1, can someone help me?
Thankyou!
