In uvm Hierarchy which one is non-virtual class???
Non-virtual uvm_sequencer:
You can directly use uvm_sequencer to connect to driver without adding extended functionality. Like,
typedef uvm_sequencer#(sequence_item) sequencer;
I don’t see any reason to write uvm_driver as non-abstract class. How would you use uvm_driver class object without extending any of its method?
