Sequencer
If my seq_item, sequence and sequencer class are same for both master and slave agent ,then can i use single seq_item, sequence and sequencer class for both of them? or is it good way to use virtual sequencer in this kind of case?
In reply to A_123:
Yes. It is very common to create an agent that can act as both a master or slave depending on how it is configured.
In reply to cgales:
Hi cgales,
Actually my both agents drive and monitor differently. so i have to keep them separate. but all transaction classes like seq_item , sequence , sequencer are same for both master and slave. so, it is possible use single transaction classes in environment and call it from agent?
In reply to A_123:
Typically a sequence_item is specific to one agent. There is no reason that you can’t code your driver/monitor to act differently based upon a configuration setting. You will often see this in an agent used for a family of protocols, such as Ethernet.
If you have the same sequence_item across several different agents, you run the risk of namespace collision and potentially using the wrong sequence_item.
Here is the link.
(naming conventions are not that much good)
In reply to cgales:
My both agents have same variables to randomize. that’s why i’m thinking to make single seq_item , sequence and sequencer class. but my both agents drives data differently. is it possible to take single seq_item , sequence and sequencer class in environment having two different handles for both agents and call it from agents? or i must have to make separate seq_item , sequence , sequencer class for both agent and put it in virtual sequencer?
here is the link : i2s_27/9 - EDA Playground
In reply to A_123:
I understood you r code as follows:
You have 1 master agent and 1 slave agent.
Each agent has a sequencer/driver pair.
The sequencers produces seq_items of the same time. They are parameterized for the same seq_item.
But the drivers differ. Correct?
You can use the seq_item for both sequencers/sequences.
The sequencer is the same. But you might need different sequences for the master and the slave.
This approach is fine.
Yes, you are getting it correct
Thank you very much @chr_sue
I’m using one sequence and one sequencer having two different handles for master and slave, is this ok?
In reply to A_123:
Yes that’s OK.
Thank you very much @chr_sue.
