Hi ,
What are the disadvantages of using a sequence_library ?
Thanks In Adv
Hi ,
Thanks In Adv
In reply to bl4ckp3rl :
I guess you mean the UVM sequence library.
There is no disadvantage using it.
One approach is to collect sequences belonging to certain verification aspects in a sequence library. Then you can start this library and all sequences belonging to it will be executed in random order.
Q] add_typewide_sequence() or add_sequence() which method is preferred for registering sequence to sequence library ?
There is nothing prefered. In the UVM we have constructs doing nearly the same. This is common behavior.
I’m using add_sequence.
Can we able to run multiple sequences parallelly using the sequence-library instead of back to back sequences to the agent
