In the below code , it is working fine without the object registration with the factory,
but showing error with the object registration. for every components and object we have to do factory registration right then why factory registration is showing error for uvm_sequence_item.
can anyone explain this.?
class and_trans extends uvm_sequence_item;
`uvm_object_utils(and_trans)
rand bit a;
rand bit b;
bit c;
function new(string name=“”);
As your simulator says, you are registering the seq_item twice with the factory.
Please be adviced it is not recommended to use the field macros. Your code should look like this:
rand bit a;
rand bit b;
bit c;
function new(string name="");
endclass : and_trans
Got it Thanks,
But without using the field macros , how it will know whether it is used to compare or not.
using field macros we can provide the following access to the variables.
UVM_COMPARE,UVM_NO_COMPARE etc…
Here in the above code, you are actually registering the ‘and_trans’ item twice with the factory that’s why you’re getting those error.
1st time just after the class template and 2nd time after the constructor.
You can use one at a time of the below registration syntax depending on your requirement.
1)uvm_object_utils(and_trans) //This is class registration with the factory or 2)uvm_object_utils_begin(and_trans) //This is class registration with the factory+field automation macros uvm_field_int(a,UVM_ALL_ON) uvm_field_int(b,UVM_ALL_ON) uvm_field_int(c,UVM_ALL_ON) uvm_object_utils_end
