As in the topic, does RUVM4.6 support few kinds of backdoor access?
I would like to reuse the verification environment for RTL and gatelevel verification of a certain DUT. I have a problem with backdoor access through the register model. The RTL and gatelevel floavor of the DUT requires slightly different backdoor hdl_paths:
- in RTL the registers are signle signals, ie. dut.register_file.conf[7:0]
- in gatelevel the registers are split to single flip-flops, ie. dut.register_file.conf_reg_7, dut.register_file.conf_reg_6 … dut.register_file.conf_reg_0
I would like to avoid having two separate registers descriptions files (.cvs) for RTL and gatelevel verification, as it could be error prone (possibility of mismatch between two descriptions). I noticed that add_hdl_path in reg_uvm has the kind argument. Thus:
- Is it possible to define in a single register description file (.cvs) for RUVM4.6 two kinds of backdoor paths?
- How to specify in the description file (.cvs) for RUVM4.6 a backdoor path combined of many single registers (according to UVM 1.1d documentation, reg_uvm.add_hdl_path could process a path defined as:
reg_h.add_hdl_path('{ '{"conf_reg_7", 7, 1},
'{"conf_reg_6", 6, 1},
'{"conf_reg_5", 5, 1},
'{"conf_reg_4", 4, 1},
'{"conf_reg_3", 3, 1},
'{"conf_reg_2", 2, 1},
'{"conf_reg_1", 1, 1},
'{"conf_reg_0", 0, 1} },
"GATELEVEL" );
