Review of AHB verification Agent: mainly on the inter class communication of REQ, RES between Driver and Sequence: Randomization for Burst mode: and Scoreboard comparison using associative storage
Firstly, apologies for lengthy question. As I’m a beginner in UVM and SystemVerilog any suggestion and constructive criticism is welcome!!
class ahb_sequence extends uvm_sequence#(type ahb_p_req = ahb_packet, type ahb_p_rsp = ahb_p_req);
	`uvm_sequence_utils(ahb_sequence,ahb_sequencer)
	req = ahb_p_req::type_id::create("req");
	int inc_undef_burst_hwrite;
	function new (string name ="ahb_sequence");
	endfunction : new
	virtual task body();
		uvm_report_info("seq","before uvm_do",UVM_NONE);
		///  vvv  ///
		start_item(req);
		if(!req.randomize())
			`uvm_error("seq", "randomization failure for req")
		int inc_undef_burst_hwrite = req.hwrite;
		if (req.hburst != 0 && req.trans=='d2)			// Entering BURST mode write/read transaction
			casez(req.hburst)							// case for one of the burst operation, in our DUT please ignore the wrapping burst
				3'b01?:
					repeat(3)							// 4-beat incrementing burst (INCR4), we use repeat 3, as first transfer has already been initiated
						finish_item(req);
						get_response(rsp); 				// complete of first transfer of Burst and from next cycle address will be incrementing by one
						start_item(req);
						if (req.htrans==2)
							req.trans='d3;
						if (req.hwrite==1)
							req.randomize(hwdata);		// radomize only H-WRITE-DATA if its a write Burst operation
				3'b10?:
					repeat(7)							// 8-beat incrementing burst (INCR8), we use repeat 7, as first transfer has already been initiated
						finish_item(req);
						start_item(req);
						if (req.htrans==2)
							req.trans='d3;
						if (req.hwrite==1)
				3'b11?:
					repeat(15)							// 16-beat incrementing burst (INCR16), we use repeat 15, as first transfer has already been initiated
						finish_item(req);
						start_item(req);
						if (req.htrans==2)
							req.trans='d3;
						if (req.hwrite==1)
				3'b001:
					do
						finish_item(req);
						start_item(req);
						if (req.htrans==2)
							req.trans='d3;
						req.randomize(hwrite);
					while(inc_undef_burst_hwrite == req.hwrite)
			endcase
		finish_item(req);
		get_response(rsp); // type of rsp = my_sequence_item2
	endtask : body
endclass : ahb_sequence
class ahb_driver extends uvm_driver#(type ahb_p_req = ahb_packet, type ahb_p_rsp = ahb_p_req);
	`uvm_component_utils(ahb_driver)
	//Interface and packet declaration
	virtual ahb_if vif;
	// ahb_packet pkt; vvv
	endfunction: new
		void'(uvm_resource_db#(virtual ahb_if)::read_by_name(.scope("ifs"),.name("ahb_if"), .val(vif)));
		uvm_config_db#(virtual interface ahb_if)::get(this,"*","ahb_if",vif);
	endfunction: build_phase
		@(posedge vif.HRESETN)
			while(1)
				//Drive the packet at the negative edge of clock
				@(negedge vif.HCLK)
					uvm_report_info(get_full_name(),"Printing the AHB packet",UVM_NONE);
					req.print();
					@(posedge vif.HCLK)
						vif.HWRITE = req.hwrite;
						vif.HADDR = req.haddr;
						if(req.hwdata==1)
							vif.HWDATA = req.hwdata;
						vif.HTRANS = req.htrans;
						vif.HSIZE = req.hsize;
						vif.HBURST = req.hburst;
					seq_item_port.item_done();
					//vvv
					rsp = ahb_p_rsp::type_id::create("rsp"); // type of rsp = ahb_p_rsp
					rsp.set_id_info(req);
					rsp.hresp = vif.HRESP;
					if(vif.HRESP)
						`uvm_error("seq", "Error in transfer response from slave")
					seq_item_port.put(rsp);
					//vvv
	endtask: run_phase
endclass: ahb_driver
class ahb_scoreboard extends uvm_scoreboard;
	`uvm_component_utils(ahb_scoreboard)
	uvm_analysis_imp #(ahb_packet,ahb_scoreboard) scb_port;
	ahb_packet ahb_scpkt;
	logic[31:0] stor_assos[*] ;
	logic[31:0] burst_addr[$];
	logic[31:0] burst_addr_temp;
	function compare (string name,uvm_component parent);
		scb_port = new("scb_port",this);
	endfunction : compare
	function new (string name,uvm_component parent);
		super.new(name,parent);
	endfunction : new
	virtual function void connect();
		super.connect();
		uvm_report_info("scb","connect method in scoreboard",UVM_NONE);
	endfunction : connect
	virtual task run_phase (uvm_phase phase);
	endtask : run_phase
	virtual function write(ahb_packet ahb_mpkt);
		uvm_report_info("scb","received packet from Monitor",UVM_NONE);
		ahb_scpkt = new();
		$cast(ahb_scpkt,ahb_mpkt.clone());
		ahb_scpkt.print();
		///  vvv  ///
		if(ahb_scpkt.hresetn =='b1 )
			if(ahb_scpkt.hwrite == 'b1)
				case(ahb_scpkt.htrans)
					2b'10:
						stor_assos[ahb_scpkt.haddr]	= ahb_scpkt.hwdata;		// Copy WRITE operation for non-BURST WRITE
						if(ahb_scpkt.hburst != 0)
							burst_addr.push_back(ahb_scpkt.haddr);			// Since we do not know the next cycle will be Burst READ we save the current memory address
						break;
					2b'11:
						casez(ahb_scpkt.hburst)
							3'b01?:
									repeat(3)
										burst_copy(ahb_scpkt);
									break;
							3'b10?:
									repeat(7)
									break;
							3'b11?:
									repeat(15)
									break;
							3'b001:
									while(ahb_scpkt.hwrite == 'b1)
									break;
							default:
								uvm_report_error("scb","Condition not valid");
						endcase
						break;
					default:
						uvm_report_info("scb","HTRANS is either 2'b00 or 2'b01 so need not write",UVM_NONE);
				endcase
			else
				if(stor_assos.exists[ahb_scpkt.haddr])
						2b'10:
								if (stor_assos[ahb_cmp_pkt.haddr]	== ahb_cmp_pkt.hrdata)		// Compare for non-burst read operations
									uvm_report_info("scb","Read data matches the written data",UVM_NONE);
								else
									uvm_report_error("scb","Read data does not matches the written data");
								break
						2b'11:
									3'b01?:
											repeat(3)
												burst_compare(ahb_scpkt);
											break;
									3'b10?:
											repeat(7)
											break;
									3'b11?:
											repeat(15)
											break;
									3'b001:
											while(ahb_scpkt.hwrite == 'b0)
											break;
									default:
								endcase
								break;
						default:
					endcase
		///  vvv  ///
	endfunction : write
	function void burst_compare (ahb_packet ahb_cmp_pkt)
		burst_addr_temp = burst_addr.pop_back();			// 	Pop the previous address
		burst_addr_temp++;									// 	Increment by one
		if (stor_assos[burst_addr_temp]	== ahb_cmp_pkt.hrdata)
		else
		burst_addr.push_back(burst_addr_temp);				//	Save the new adress in the Queue
	function void burst_copy (ahb_packet ahb_cpy_pkt)
		stor_assos[burst_addr_temp]	= ahb_cpy_pkt.hwdata;   //	Save in memory location
endclass : ahb_scoreboard
In reply to vvv:
Few low hanging fruits (from a review perspective, non-exhaustive):
  1. Avoid uvm_sequence_utils - it is removed from 1.2 onwards
  2. uvm_info, uvm_error macros are handier than uvm_report_info etc.
  3. seq::body should call crate_item inside the loop (as of now you have it outside the loop) - this will enable late factory overrides.
  4. Use get_name() for IDs in messages than inventing your own
  5. Change: scoreboard::connect → scoreboard::connect_phase
  6. Driver uses posedge/negedge - instead use clocking blocks and avoid edges in driver/monitor
  7. signal level comparisons could better use === instead of ==
  8. Better indentation (2 space is what I prefer)
  9. req.randomize → UVM internally uses a pre-defined ID RNDFLD, better stick to that: e.g.
   `uvm_warning("RNDFLD", "Randomization failed in uvm_do_with action")
(In fact I have a tiny macro `vw_uvm_rand for doing that)
10. Where are the assertions BTW? (Perhaps not shown, but ideal to use SVA for standard protocols like this)
Good Luck
Srini
www.verifworks.com
In reply to Srini @ CVCblr.com:
Thanks a ton Srini, I appreciate for taking time and reviewing my code, I will surely consider your suggestions and follow it.
In addition, I had following doubts in the above code,
  1. Rsp sent by driver to sequence is good in my code? I’m doubtful about that and I have declared those variable correctly in the class?
  2. I’m I using correct way to store the written variable in scoreboard?? (including burst mode)
  3. If u ask me, assertions are my weak point could you please tell me why we need to use it here in this case even though we are verifying it in other ways.
  4. Also I have a question on how I can implement assertions in UVM or should I instantiate another module in ‘top-module’ and go ahead with concurrent assertion in it??
    It would be great if you could share an example protocol verification which uses both UVM and assertions.
Once again thank you for your time.
