I have a block level scoreboard that uses the block level register model for checking, and have a question about reusing this scoreboard at chip level. The scoreboard uses register peeks to do checking, which of course relies on the correct hdl path to the register.
I know how to integrate the unit level environment and register model in our chip level environment, but want to know if there is an easy way to update the hdl_path in the block level register model so it is correct at chip level. We don't have a chip level register model, but could create one if it helps solve the problem.
The block level register model hdl paths are specified as follows:
add_hdl_path("block_name_tb.dut_wrapper.dut");
register_name_h = register_name::type_id::create("register_name_h");
register_name_h.configure(this, null, "block_name_reg_array_i.register_name_rd");
register_name_h.build();
Should I create a chip level register model that clears the hdl_path, then adds in the correct chip level path?
Ideas?
