Name Type Size Value
Result reached the maximum of 5000 lines. Killing process.
Execution interrupted or reached maximum runtime.
Done
I have not added any simulation time-out limit. I am not able to spot an infinite loop code. Could you help find out if there is one? If not, what else could cause this error?
Looks like you are facing a tool issue.
But I found 2 errors in the file packet_seqeuence.sv
line 117 should be
`uvm_do_with(req, {if (port_id == -1) sa inside {[0:15]}; else sa == port_id; da inside {valid_da};})
A macro call has never a semicolon at the end.
The inside operator requires a range indicated by {}.
It runs fime with Questa after fixing these issues.
