Is 'req' reserve keyword in uvm?
Dear All,
I’m trying to understand the below code. In especially,
Where exactly ‘req’ comes from?
module test_top;
`include "uvm_macros.svh"
`include "uart_frame.sv"
class uart_sequencer extends uvm_sequencer #(uart_frame);
`uvm_component_utils(uart_sequencer)
endfunction : new
endclass : uart_sequencer
class uart_tx_driver extends uvm_driver #(uart_frame);    //lab2_note3
int frames_sent;
`uvm_component_utils(uart_tx_driver)         //lab2_note4
    frames_sent++;
    send_to_dut(req);
    seq_item_port.item_done();
endtask : run_phase
task send_to_dut(uart_frame frame);
   repeat (frame.delay)
 endtask : send_to_dut
endfunction : new
endclass : uart_tx_driver
`include "uart_seq_lib.sv"
uart_sequencer  sequencer;
uart_tx_driver  driver;
	  uvm_config_wrapper::set(null, "sequencer.run_phase", "default_sequence",
	  					uart_nested_seq::type_id::get());
  sequencer = new("sequencer", null);
  driver = new("driver", null);
  run_test();
class uart_base_seq extends uvm_sequence #(uart_frame);
  `uvm_object_utils(uart_base_seq)
  function new(string name="uart_base_seq");
  task pre_body();
    starting_phase.raise_objection(this, get_type_name());
    `uvm_info(get_type_name(), "raise objection", UVM_MEDIUM)
    uvm_test_done.set_drain_time(this, 200ns);
  endtask : pre_body
  task post_body();
    starting_phase.drop_objection(this, get_type_name());
    `uvm_info(get_type_name(), "drop objection", UVM_MEDIUM)
  endtask : post_body
endclass : uart_base_seq
class uart_transmit_seq extends uart_base_seq;
  `uvm_object_utils(uart_transmit_seq)
   rand int unsigned NumOfTx;
   function new(string name="uart_transmit_seq");
   constraint NumOfTx_ct { NumOfTx >0; NumOfTx <= 10; }
   virtual task body();
     uvm_report_info("uart_transmit_seq", $psprintf("Executing %0d times", NumOfTx), UVM_LOW);
     for (int i = 0; i < NumOfTx; i++) begin
        `uvm_do(req)
   endtask: body
endclass: uart_transmit_seq
class uart_nested_seq extends uart_base_seq;
  uart_transmit_seq     transmit_seq;
  `uvm_object_utils(uart_nested_seq)
        `uvm_do_with(transmit_seq, {NumOfTx==3;})
   endtask: body
endclass: uart_nested_seq
From example above, WE can see the ‘req’ keyword used in a sequence class without any declaration.
So I want to know that can we use ‘req’ keyword without something relative declaration? does it reservation keyword for UVM?
In reply to UVM_LOVE:
req is inherited from the base class uvm_driver.
