Even though I have added the condition in the report catcher, still it is unable to catch. Can anyone help me what I am doing wrong or any new solution to suppress to those errors.
In reply to sumanth291092:
Code:
class report_catcher extends uvm_report_catcher;
bit err_demoted;
`uvm_object_utils(report_catcher)
function new(string name=“report_catcher”);
endfunction : new
function action_e catch();
if ((get_severity() == UVM_ERROR) && ((get_message() == “-----### I2C ERROR : sending data, expected ack not correct ###-----”) || (uvm_is_match(“/-----### DATA BIT SEND IS NOT ACKNOWLEGED /”,get_message())) || (uvm_is_match(“/I3C_MST_DRIVEN_EVEN_PARITY_FOR_PVT_WDATA - /”,get_message())) || (uvm_is_match(“/I3C_MSG_WITH_UNALLOCATED_DYNAMIC_ADDR - /”,get_message())) || (uvm_is_match(“/I3C_STOP_FLWD_BY_DATA - /”, get_message())) || (uvm_is_match(“/I3C_STOP_BTW_DATA_9_BITS - /”, get_message())) || (uvm_is_match(“/I3C_MST_DRIVEN_EVEN_PARITY_FOR_CCC_BYTE - /”, get_message())) || (uvm_is_match(“/I3C_BCST_CCC_ENTAS0_WITH_WDATA - /”, get_message())) || (uvm_is_match(“/The START SETUP TIME shall not be more than SCL HIGH TIME /”, get_message())) || (uvm_is_match(“/I3C_MST_DRIVEN_EVEN_PARITY_FOR_BCST_CCC_WDATA - /”, get_message())) || (uvm_is_match(“/I3C_RSTART_BTW_DATA_9_BITS - /”, get_message())) || (uvm_is_match(“/I3C_MST_DRIVEN_EVEN_PARITY_FOR_DAR - /”, get_message())) || (uvm_is_match(“/I3C_7E_RD_AFTER_CCC_ENTDAA_FLWD_BY_NACK - /”, get_message())) || (uvm_is_match(“/I3C_7E_RD_AFTER_CCC_ENTDAA_FLWD_BY_NACK - /”, get_message())) || (uvm_is_match(“/I3C_VAL_NOT_7E_RD_DURING_DAA - /”, get_message())) || (uvm_is_match(“/I3C_7E_WR_FLWD_BY_NACK - /”, get_message()))|| (uvm_is_match(“/No address to select from addr_arr/”, get_message())) || (get_id()== “rst_int_on”) || (get_id()==“wr_seq”) || (uvm_is_match(“/RESET NIRQ register read back is incorrect!!/”, get_message())) ))
set_severity(UVM_INFO);
err_demoted = 1;
return THROW;
endfunction : catch
endclass : report_catcher
Sim.log
UVM_ERROR /eda/local/tools/mentor/questa_vip/2021.4_20211024/questa_mvc_src/sv/i3c/sequence_lib/base/i3c_api.svh(1511) @ 2164522750: uvm_test_top.i3c_env.dev_mst_agent.sequencer@@rd_seq**[rd_seq] No address to select from addr_arr**
UVM_ERROR /eda/dm/home/skotareddy/jhr3023/v1a/digital/chip/verif/seq/power_up_seq.sv(219) @ 2166231250: uvm_test_top.i3c_env.dev_mst_agent.sequencer@@pwrup_seq [rst_int_on] RESET NIRQ register read back is incorrect!!
You should specify what your report_catcher should do. Your description is unclear.
And your catch function should start to get the current status and afterwards doing your changes like this:
function action_e catch;
uvm_severity severity = get_severity();
string id = get_id();
uvm_action action = get_action();
string message = get_message();
int verbosity = get_verbosity();
if (severity == UVM_WARNING) //demoting all UVM_WARNING to UVM_INFO
if (severity == UVM_ERROR) // UVM_ERROR goes not further
return CAUGHT;
return THROW; // all other messages are thrown to other report_catcher
HI,
I have tried the solution but had no luck in capturing those errors. There are other UVM ERRORS that are being suppressed but not the following.
Following errors are not being suppresed:
UVM_ERROR /eda/local/tools/mentor/questa_vip/2021.4_20211024/questa_mvc_src/sv/i3c/sequence_lib/base/i3c_api.svh(1511) @ 2164522750: uvm_test_top.i3c_env.dev_mst_agent.sequencer@@rd_seq [rd_seq] No address to select from addr_arr
Could you please show the whole related code including the construction of your report_catcher.
class my_msg_catcher extends uvm_report_catcher;
bit err_demoted;
`uvm_object_utils(my_msg_catcher)
function new(string name="my_msg_catcher");
return CAUGHT;
endclass : my_msg_catcher
Test:
`ifndef CHIP_PWRUP_FB_I3C_BYPASS_TEST__SV
`define CHIP_PWRUP_FB_I3C_BYPASS_TEST__SV
class chip_pwrup_fb_i3c_bypass_i3c_test extends i3c_base_test;
my_msg_catcher rpt_catcher;
`uvm_component_utils(chip_pwrup_fb_i3c_bypass_i3c_test)
super.new(name,parent);
endfunction: new
rpt_catcher = my_msg_catcher::type_id::create(.name("rpt_catcher"),.contxt(get_full_name()));
chip_cfg.chipSetting = TIME_OPTIMAL;
chip_cfg.opSetting = IRQ;
/*function void set_report_severity_override( uvm_severity UVM_ERROR,
uvm_severity UVM_WARNING);
endfunction */
chip_pwrup_fb_i3c_bypass_seq test_seq;
super.run_phase(phase);
phase.raise_objection(.obj(this));
test_seq=chip_pwrup_fb_i3c_bypass_seq::type_id::create(.name("test_seq"),.contxt(get_full_name()));
uvm_report_cb::add(null, rpt_catcher);
test_seq.start(.sequencer(i3c_env.dev_mst_agent.m_sequencer));
uvm_report_cb::delete(null, rpt_catcher);
phase.drop_objection(.obj(this));
endclass: chip_pwrup_fb_i3c_bypass_i3c_test
`endif
I have modified the below code to match your error message and it is working as expected.
// Code your testbench here
// or browse Examples
`include "uvm_macros.svh"
program tb;
class transaction extends uvm_object;
rand bit[3:0] data;
rand bit[5:0] addr;
rand bit wr_en;
`uvm_object_utils_begin(transaction);
`uvm_field_int(data,UVM_ALL_ON)
`uvm_field_int(addr,UVM_ALL_ON)
`uvm_field_int(wr_en,UVM_ALL_ON)
`uvm_object_utils_end;
function new (string name = "transaction");
// comp_a has 1 UVM_LOW and 1 UVM_MEDIUM message
class comp_a extends uvm_component;
`uvm_component_utils (comp_a)
uvm_analysis_port #(transaction) broadcast_port;
function new (string name = "comp_a", uvm_component parent);
broadcast_port = new("broadcast_port",this);
transaction tx;
tx = transaction::type_id::create("tx", this);
void'(tx.randomize());
`uvm_info(get_type_name(),$sformatf(" tranaction randomized"),UVM_LOW)
tx.print();
`uvm_info(get_type_name(),$sformatf(" tranaction sending to comp_c"),UVM_MEDIUM)
broadcast_port.write(tx);
// comp_b has 1 UVM_HIGH and 1 UVM_LOW messages
class comp_b extends uvm_component;
`uvm_component_utils (comp_b)
uvm_analysis_port #(transaction) aport_send;
function new (string name = "comp_b", uvm_component parent);
aport_send = new("aport_send",this);
transaction trans;
trans = transaction::type_id::create("trans", this);
trans.data = 4'h3;
trans.addr = 6'h10;
trans.wr_en = 1;
`uvm_info(get_type_name(),$sformatf(" tranaction not randomized"),UVM_HIGH)
trans.print();
`uvm_info(get_type_name(),$sformatf(" tranaction sending to comp_c"),UVM_LOW)
aport_send.write(trans);
// comp_c has 2 UVM_LOW messages
`uvm_analysis_imp_decl(_comp_a)
`uvm_analysis_imp_decl(_comp_b)
class comp_c extends uvm_component;
`uvm_component_utils (comp_c)
uvm_analysis_imp_comp_a #(transaction,comp_c) comp_a_export;
uvm_analysis_imp_comp_b #(transaction,comp_c) comp_b_export;
function new (string name = "comp_c", uvm_component parent);
comp_a_export = new ("comp_a_export",this);
comp_b_export = new ("comp_b_export",this);
function void write_comp_a (transaction t);
`uvm_info(get_type_name(),$sformatf(" transaction Received in scoreboard comp_a"),UVM_LOW)
t.print();
function void write_comp_b (transaction tr);
`uvm_info(get_type_name(),$sformatf(" transaction Received in scoreboard comp_b"),UVM_LOW)
`uvm_error (get_type_name(),"Error in comp_c");
tr.print();
// Env has 1 UVM_DEBUG message
class my_env extends uvm_env;
`uvm_component_utils(my_env)
comp_a test_a;
comp_b test_b;
comp_c test_c;
function new (string name = "my_env", uvm_component parent=null);
test_a = comp_a::type_id::create("test_a",this);
test_b = comp_b::type_id::create("test_b",this);
test_c = comp_c::type_id::create("test_c",this);
test_a.broadcast_port.connect(test_c.comp_a_export);
test_b.aport_send.connect(test_c.comp_b_export);
`uvm_info ("my_env", "Demonstrating UVM_DEBUG message from my_env",UVM_DEBUG);
class my_report_catcher extends uvm_report_catcher;
`uvm_object_utils (my_report_catcher)
function new (string name = "");
if ((get_severity() == UVM_ERROR) && ((uvm_is_match("RESET NIRQ register read back is incorrect!!", get_message())) )) begin
// get_client().die();
return THROW;
endclass : my_report_catcher
// Test has 1 uvm_full and 1 uvm_low messages
my_env env;
my_report_catcher rc;
function new(string name = "base_test",uvm_component parent=null);
endfunction : new
env = my_env::type_id::create("env", this);
rc = new("rc");
uvm_report_cb::add(null, rc);
endfunction : build_phase
function void end_of_elaboration();
print();
phase.raise_objection(this);
`uvm_error ("Inside_test","RESET NIRQ register read back is incorrect!!");
#500
`uvm_error ("Inside_test","Example to demonstrate UVM_LOW from base_test");
phase.drop_objection(this);
endclass : base_test
run_test("base_test");
endprogram
In reply to rag123:
I Have tried the solution given, still no luck. Those UVM_ERRORS are not being suppressed.
I can’t understand what is problem
Your requirement is not clear to me. You can demote a UVM_ERROR depending on the ID (1st argument in the uvm_error) or on the message (2nd arg). Please show the codelines of
uvm_error you want to suppress.
