Register adapter using sequence layering
Hello,
I have VIP for a custom interface that is not generated thinking of using register modeling. In this environment my register adapter needs to use sequence instead of sequence item. As I learned while investigating the solution that it requires sequence layering.
Are there any examples for register adapter using sequence layering?
Best regards,
Rifat
In reply to rdemirci:
I’m not sure if your assumption is correct. Finally the adapter is intended to process sequence items (transactions). You can extend this transaction class instead.
