Register access using object
Hello Forum,
I am verifying the protocol interface using UVM-1.1d and QuestaSim-10.2b.
Could you please help me to resolve the following doubt:
class clk_gen extends uvm_component;
  `uvm_component_utils(clk_gen)
   REG_BLOCK rb;
   virtual cmi_if intf;
		clk_gen();
	endtask : run_phase
	task get_current_mach();
       if(rb.inst_tx_mode.get() == 2)   // Getting error here. Here, "inst_tx_mode" is the register defined in the "REG_BLOCK"
	task clk_gen();
              get_current_mach(); // Here we are calling the above task.
endclass :clk_gen
Here the error i am getting is:
# ** Fatal: (SIGSEGV) Bad handle or reference.
#    Time: 0 ps  Iteration: 46  Process: /pkg::clk_gen::clk_gen/#FORK#75_fe2d7ba File: clk_gen.sv
# Fatal error in Task pkg/clk_gen::get_current_gear at clk_gen.sv line 42
  1. Do i need to define build_phase to create the “rb” object and config_db to get the interface.
Please help and suggest.
Thanks and Regards
Sunil S.
In reply to sunils:
You have to create your register model only ones. It is agood approach to have a handle of your gegister model in a configuration object. From there you can connect any handle of the register model.
Hello Chr_Sue,
It is resolved with your approach. Thanks for suggestion.
Thanks and Regards,
Sunil S.
