I have a register bank, which can be accessed by 3 different interfaces (different protocols). How can I implement this using RAL.
a) Should I have 3 instances of the reg model and connect them to the three different sequencers ?
b) If I write through one interface - say reg1 through IF1, how can I make sure the reg1 values will get reflected for the other interface also (since it is the same set of registers)
Thanks in advance.
In reply to umagraman:
You can take multiple register map instances and configure them for a number of required interfaces. you can refer the following document for multiple register map ([Click hereā¦])(Section : RAL register map and adapter)
Also, find answers inline.
a) Should I have 3 instances of the reg model and connect them to the three different sequencers?
Answer:- Yes, For each bus, a sequencer is required to be configured.
Answer:- Ideally, this should be your test criteria as the register is the same but access interface is different. You can write register with one register map and read_compare with other all register maps. (There is an inbuilt register sequence (uvm_reg_shared_access_seq) which you can use)
Regards,
Mitesh Patel
In reply to mitesh.patel:
Thank you Mitesh.
Hi Mitesh
How will the write method distinguish which interface it has to use among the 3 - cause I am not passing any details on that
- reg1.write(value) // Write thru IF1
- reg2.write(value) // write thru IF2
- reg3.write(value) // writhe thru IF3
Regards
Uma
The map associated with a register object dictates which interface it uses. If you have a register associated with multiple maps, you must provide the map detail when calling write(). There is no default map.
When you are dealing with multiple bus interfaces, then each interface must be allocated for separate register map. from the write method, the user has to pass the map handle ( which will drive to an allocated interface).
Thanks Dave.
In my case, the 2 interfaces dont have seperate Base Address. We differentiate them by writing a particular value into interface_no register. Eg., If IF1 wants to write the DUT registers, it writes the register address in a predefined address - say 1A. If IF2 wants to write the same regsiter, it writes the register address into -1B.
So,when I create the map for IF1 and IF2, BA and offset will be same
So, even if I pass the register map for IF1,IF2 during calls to write or read, will it be able to differentiate?
Or Should I pass any more options.
Thank you Mitesh.
