Hello !
Have a scenario where I store all the sequencer handles in an associative array for easy access from the top level test.
As the env gets created, the respective sequencer handles inside the agent in env gets added to this associative array pool. For eg, as shown below:
uvm_sequencer_base seqr_pool[string]
// Tag the sequencer handle with a string name
It was fine for single layer environments i.e. an env containing other env’s. But it looked hard if the case was a top level env, containing N-instance of sub-envs, because there will be name scope collision.
- To overcome this added the entire path of the sequencer as string search as each of them will be unique as the component gets created. For eg. like given below
// String name - Component handle : seqr_pool[name] = sequencer handle
"uvm_test_top.top_env.env[0].which_agt[0].seqr", uvm_test_top.top_env.env[0].which_agt[0].seqr
"uvm_test_top.top_env.env[1].which_agt[0].seqr", uvm_test_top.top_env.env[1].which_agt[0].seqr
- When I looked for the sequencer in the pool, I passed the string as regex
launch_sequence_api(".*env\\[1\\].which_agt\\[0\\]", ...);
- Stumbled across this uvm_re_match DPI and put together this simple helper function to search for that string in the associative array pool.
function uvm_sequencer_base sequencer_pool::which_seqr(string name);
bit seqr_found = 0;
foreach(seqr_pool[i]) begin
if (!uvm_re_match($psprintf("%s", name), $psprintf("%s", seqr_pool[i].get_full_name()))) begin
seqr_found = 1; seqr_temp = sqrtab[i];
$display("Matched: name: %s, seqr_pool: %s\n", name, seqr_pool[i].get_full_name());
break;
else begin
seqr_found = 0;
$display("Mismatched: name: %s, seqr_pool: %s\n", name, seqr_pool[i].get_full_name());
if(!seqr_found)
`uvm_error(get_type_name(), $psprintf("sqr reference is not available in common_sequencer_container for %s name", name));
return null;
else
return seqr_temp;
endfunction: which_seqr
Would this be fine ? Or is there a simple way of string matching/searching for such kinda-off scenarios ? Share in your comments.
In reply to desperadorocks:
I do not understand your efforts and wasting resources with a 2nd database to store sequencers.
All what you are doing is already available from the factory.
Hello @Chris,
Can you please elaborate more on your comment ? You mean to use the config_db/resource_db ? or is there anything else ?
Which would be the best case scenario as a place holder for all the sequencer handles in a single place so that we can pick-n-choose which ever sequencer we wanted at the top level test.
Also, to make sure it can sustain scalability like taking care of N-instance of env’s and other inter dependent env’s.
Please share in your comments !
@chris
It would be nice if you can add more comments from your side so that it gives a clear idea.
@All:
It would be nice if anyone can share some insight/comments/experience on this area.
Thanks !
The factory stores all your class objects (extensions from uvm_component/uvm_object). And they are sorting them with respect to belonging to the same family (inheritence).
Using the get_sequencer command (defined on the seq_item) it returns you the right sequencer.
Hello! Thanks for your response.
Sorry for more question. But still for that particular sequence you need to be setting the sequencer on which you need to run right ? So how do you set that ? Ultimately you do by sequence.start(sequencer). So this will internally does the processing etc. and sets to the m_sequencer.
What I was trying is a light weight array/pool/container, which contains all the sequencer handles etc. tagged with the string names for them to access the class handle when these components gets created [not the entire list of components like factory]. So then I can use the uvm_re_match to get the sequencer handle from the pool and call the required sequence to run on respective sequencer which I wanted to run.
So instead of a person running a sequence at the test like,
// Providing the entire path of the sequencer
sequence.start(tb_env.tb_agt.tb_seqr);
What I am doing is like,
// This returns the handle for that particular sequencer.
uvm_sequencer_base local_seqr = which_sequencer_api(".*tb_agt.*");
sequence.start(local_seqr);
// Imagine if the above case expands to multiple env/agt scenario
Is there any other ways to get things done better. Please let me know.
How many different sequencers do you have? 5, 10 or 15? In any case it is a small amount of sequencers. If you have more than 1 agent you should use virtual sequences. The virtual sequence will be started from the test on a virtual sequencer or on null. You can have in the virtual sequencer handles to the local/agent sequencers. This allows you to start your local sequences like this:
agent1_seq.start(agent1_seqr);
agent2_seq.start(agent2_seqr);
You do not need any path information. I understand your concept. But it requires always to be maintained. This might be a risk.
Hello @Chris,
Thanks a lot for taking time and providing your inputs. Appreciate your time !
