Hello team,
Can I use UVM Connect when I have C++ packet generator and Systemverilog(UVM) based driver and other TB components.
Is there any example code for this?
Regards,
Shivakumar
Hello team,
Regards,
Shivakumar
In reply to Shivakumar AN:
The UVM-Connect was developed to integrate SystemC components into a UVM Environment.
If you have C++ Code you can use it through the DPI in a UVM Environment.
